i can't play games after installing with daemon tools
  • i can't play games after installing with daemon tools
    Operating System: windows xp home
    Burning Software: nero 6
    Anti-virus Software: F-Secure
    DAEMON Tools Version: 3.46
    hi
    i installed some games (bin cue iso) with daemon tools and the installing was fine but when i try to play the game i got an error :
    (the game) disk dosen't appear to be in my cd-rom drive.please insert it and try again
    what do i do to fix this???
    it give the same error on all the games i installed
    thank you
    Do any of the games work with the original discs?
    There might be problem with your cue sheets, please post the contents of a couple of your .cue files here (simply open with Notepad and copy'n'paste here).
    Win2k3 & OSX Intel, 2GB DDR400 P4 2.6@3.55 H2O, 7800 GTX @480/1250 H2O, 1x74GB Raptor, 8x400GB RAID5
      ok thanks this is one of the cue files:
      FILE "C:\Documents and Settings\all\Desktop\New Folder\010124_1630.BIN" BINARY
      TRACK 01 MODE2/2352
      INDEX 01 00:00:00
        This cue sheet looks odd, like a Playstation game.
        Try changing the "C:\Documents and Settings\all\Desktop\New Folder\010124_1630.BIN" to "010124_1630.BIN" and check that both the .bin file and the .cue are on the same directroy.
        Also, does the game work with an original CD?
          ok ill try it and let you know
          thanks
