Showing results 1 to 4 of 4
Thread: Windows hangs after installing DT
    Default Windows hangs after installing DT
    Operating System: Windows 2000 Prof. SP4
    Burning Software: Easy CD Creator
    Anti-virus Software: Norton AV
    DAEMON Tools Version: 3.44
    Windows hangs during startup after installing DT!
    Started in safe mode and removed DT drivers (d344prt.sys and d344bus.sys) and PnP BIOS Extension, but it doesn't make any difference.
    Any ideas?
    Try to remove Daemon Tools manually (check thread about error 25002 in common problems and solutions forum). But if you even get that problem/hang after removal of Daemon Tools drivers, it's not caused by Daemon Tools.
    Did exactly as described. Does the description apply only to the 3.46/3.47 versions, or are there any additional steps (or files) to remove ver 3.44..??
    Impressive response time by the way...30 seconds, not bad )
    You can also check this thread and this thread.
