Showing results 1 to 2 of 2
Thread: reWASD does not open, !
    Default reWASD does not open, !
    I have windows 8, and i intalled reWASD
    icon show up in option bar under the small triangle
    I connect my xbox one controller throuth bluetooth, it detect it
    then i click on open reWASD, it show up in Task manager 3 second then go away
    Nothing is happening, already try to uninstall and re-install, problem still here.
    Administrator
    SUPPORT1's Avatar
    07.02.2012
    389
    Does reWASD open without the controller connected? Did you open via Admin? Does reWASD open if the controller connected via cable?
    Don't worry! Be Happy!
