Showing results 1 to 2 of 2
Thread: Help!!! How to use rotation combo
    Default Help!!! How to use rotation combo
    Can I create such a combo?
    An example
    Xbos Pad:Press [Y] Keyboard:[1]
    Xbos Pad:Press [Y] Keyboard:[2]
    Xbos Pad:Press [Y] Keyboard:[3]
    Every time you press Y, the keys are sequentially pressed.
    However, if the key is not pressed for a certain time, the combo will start from the beginning.
    wait 10sec
    We assume a common key combo for MMORPG.
    FFXIV etc.
    An example
    wait 10sec
    FFXIV etc.
    Administrator
    SUPPORT1's Avatar
    07.02.2012
    389
    Such sequence you can create using KeyCombo feature and breaks - http://joxi.ru/krDlaRpIKJy0er. But no able to reset the sequence from the beginning. We will contact it into account to try implement in further versions.
    Don't worry! Be Happy!
