Showing results 1 to 2 of 2
Thread: Left trigger toggle for aiming-We can´t do this in reWASD but yes from bigpicture
    10.11.2018
    14
    Default Left trigger toggle for aiming-We can´t do this in reWASD but yes from bigpicture
    In bigpictures - steam, there is an option for getting left trigger toggle if you want use it very useful for aiming without holding while you aim.
    analog trigger output = analog disabled
    soft touch action= left trigger
    toggle function=enabled
    I would really like use only reWASD, but we are still depending of bigpicture from steam for settings like this.
    An update with this option would be fantastic. Why we can´t do this in reWASD?
    Administrator
    SUPPORT1's Avatar
    07.02.2012
    414
    reWASD can do it. Go to the reWASD and select trigger. Set "Toggle" option and unmap button, just like that - http://joxi.ru/bmozyJos39JBQr. reWASD will create a virtual controller for toggling, in the game one pressed trigger behaves as always pressed the trigger for aiming.
    Don't worry! Be Happy!
