Controller won't connect
in rewasd the controller wont connect.. therefore it wont apply any changes to the controller.. the controller itself is working fine in game although my back buttons now do nothing... this hasnt happened before and i have tried everything to make it connect... there isnt even anything in rewasd to do.. its always just worked in the past...
Please specify did you update reWASD recently? How do you connect the controller via cable or wireless? What description do you see a left bottom of main windows, like "Please, connect gamepad" or something else? What vendor of a controller?
Also, go to the C:\ProgramData\Disc-Soft\reWASD\Logs and remove version.log in case this file there, re-open the reWASD and try to connect the controller again.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
