View Poll Results: What do you use?
Voters
140. You may not vote on this poll
  • Alcohol 120%
    108 77.14%
  • CloneCD
    15 10.71%
  • Other (Please post which and why)
    17 12.14%
Page 5 of 6 FirstFirst ... 3456 LastLast
Showing results 41 to 50 of 57
Thread: CloneCD or Alcohol 120%
  1. #41
    Hi, I use alcohol120%. There's always something with clonecd or clonedvd. Alcohol120% works easier I think. Maybe I haven't figured out how clonecd works , maybe that's it, so I stick to alcohol .
  2. #42
    I use Nero:wink: . It may not be the best burning program, but it sure works for me .
  3. #43
    13.10.2005
    334
    Quote Originally Posted by robotangel
    It works good for me... You can't make a BWA from Protections that are based on "Bad Sectors".
    I can't make a BWA at all, actually. Alcohol has problems with my drive, where DPM extraction is really slow. I would like to try if BWA builder works, but the program refuses to do so. People say that BB doesn't work with the trial version of BW. That's fine with me, but I think VSO should make BB work with the trial too, unless they want to lose potentional customers.
  4. #44
    13.10.2005
    334
    Quote Originally Posted by Kaloyan_78
    Actually, Nero with Safedisc DVDs works just fine. It even works with some CD protections.
  5. #45
    Quote Originally Posted by Nikos
    I've got the Trail, too, but it works fine.
    You can try to download and install BWABulider only: http://vso.nerim.net/BlindWrite_BWABuilder5_setup.exe
    Maybe I should say that I got the BlindWrite 4.5 Trail
    ... and who are YOU?
  6. #46
    Frage Daemon v4
    now i vote for alcohol but when i vote for daemon tools v4 ?
  7. #47
    Daumen hoch Blindwrite 5.2.23.156
    I was forced to use Blindwrite (new version) because starforce completely disables the selection of High DPM in alcohol......now ive changed im completely happy with the new version of Blindwrite....its far quicker than alcohol....and it makes 100% DPM images that work every time with automatic settings well done VSO............
    The lord giveth and the lord taketh away........
    ReBeLlIoN
  8. #48
    Blinzeln Alcohol 120% Poll results...
    78% seem to go for Alcohol 120%.......
    Now it is clear why the new Starforce 3.6+ is targeting Alcohol 120% at the moment, it is disabling the High DPM setting, you will be able to set it at High DPM.....but when it comes to the read, it will state the DPM setting is "Normal"..............
    New Blindwrite is unaffected for now.......
    ReBeLlIoN
  9. #49
    Default any evidence for Alcohol's DPM High being disabled by Starforce?
    Off topic for the CloneCD/Alcohol vote:
    Is there any evidence that Starforce disables Alcohol's DPM High setting (even with all Starforce drivers properly uninstalled)? Modified or deleted Alcohol registry keys or modified/deleted Hardware capabilities database (ex. DevSupp.dll)?
    And can anyone blame a specific version/revision of Starforce?
  10. #50
    i vote blindwrite cause it has never let me down
