View Poll Results: What do you use?
Voters
140. You may not vote on this poll
  • Alcohol 120%
    108 77.14%
  • CloneCD
    15 10.71%
  • Other (Please post which and why)
    17 12.14%
Page 6 of 6 FirstFirst ... 456
Showing results 51 to 57 of 57
Thread: CloneCD or Alcohol 120%
  1. #51
    Well ive emailed the problems I have been experiencing with Alcohol to Alcohol-soft and they have replied with thanks for highlighting the issues with starforce 3.6.10.06, its now been passed on to their developement team. Apart from that I can say no more.....except
    Cant wait for the new version!
    ReBeLlIoN
  2. #52
    05.12.2005
    17
    Ausrufezeichen starforce affects alcohol120%
    hey guys i would not prefer to use alcohol120% after installing a starforce protected game becoz the starforce system dosent allow you to make raw copies of securom or starforce cds. It ejects the disk before the writing is completed.
    it says"Something is wrong in recording procedure, save log file and report to forum"
    but the same burning of the cd i did in my frendz comp and it completed succesfully.(There was no starforce protected game installed in the system so it worked)
    I can assure you this, try out guys...
  3. #53
    06.01.2006
    1
    thank you,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
  4. #54
    Daumen hoch Alcohol 120%
    I use Alcohol 120%. Very good indeed.
  5. #55
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    @joel
    Can you blame Alcohol because StarForce messes with it? StarForce also causes BSODs when installing Alcohol on a system that already has the SF drivers installed, can you say that's Alcohols fault as well? Just use the SF removal tool and try again. It should work fine.
  6. #56
    13.11.2005
    472
    I prefer Alcohol, CloneCD is sort of... ugh...
  7. #57
    I went with blindwite, becuase it plays well with window 64. No other reason then that.
