Some Problems with StarForce
  • Some Problems with StarForce
    I tried to make a copy of game Scrapland(StarForce 3.5...).
    I made image with BlindWrite(last version) with automatic profile and mounted it with daemon tools(3.47).
    But disk didn't checked and i couldn't start the game.
    Then I made image with alcohol 120%(1.9.5.802)
    and mounted it with daemon, but result was the same.'
    What could I do?
    I thinked that "DAEMON Tools is able to support this protection 100%"
    I'm very sad.:cry:
    If in my post there are errors, do not be angry, because I'm Russian
    Well, Starforce has been discussed 25455 times here and all the conclusions were the same : "Starforce beats D-Tools". So use your original CD/DVD.
    For the moment.. :P
      here's a temp solution
      okay, I got the PSI OPS, and it uses starforce, what I had to do, was download I believe Starforce Nightmare, and disable the cd, node, and ide channels, and them mount the image of the game using d-tools. and it worked. dunno if this helps.
        Should work with .mds like a charm - it does with me. BTW, it's SF 3.4.
          Disabling the IDE drives only works with the older versions of Starforce. It does not work against Starforce 3.5.
            I only know that PSI OPS is one of the newer games with starforce, dunno which vers. Only trying to through out suggestions.
