Showing results 1 to 2 of 2
Thread: SCSI disc & Windows 10 LTSB
    Default SCSI disc & Windows 10 LTSB
    I already have found that I need to update my Windows 10 to the latest one (1809) to get no Error 55 when mounting SCSI disc with my Daemon Tools 8 Pro. But the problem is that I have LTSB version of OS (version from systeminfo 10.0.14393, 14393) and if I am right I can't install updates (Windows update service doesn't show I have available updates and manual update showed that there is newer 1809 version but I can't install it). Is there any way to solve my problem?
    Thanks in advance.
    Administrator
    SUPPORT1's Avatar
    07.02.2012
    364
    Such an issue is known with ver. 1803 which completely, but it completely fixes with 1809 update, though. Therefore, I would recommend installing the latest available 1809 using the MediaCreationTool1809.exe
    downloaded from official MS website - https://www.microsoft.com/en-us/soft...load/windows10.
    Are IDE devices creating well?
    Don't worry! Be Happy!
