Showing results 1 to 2 of 2
Thread: Probleme mit SPTD Treiber 212 für 64Bit unter Windows 10 v. 1903
    Default Probleme mit SPTD Treiber 212 für 64Bit unter Windows 10 v. 1903
    Hey,
    Ich wollte die DTPro821-0709. mit den SPTD Treiber 212 für 64Bit unter Windows 10 v. 1903 installieren . gibt dann Probleme mit denn SPTD Treiber 212 . In Geräte Manager steht das die SATA Treiber nicht geladen werden können.
    Administrator
    SUPPORT1's Avatar
    07.02.2012
    361
    With Windows 10 version 1903, Microsoft has implemented several crucial kernel changes that have a significant influence on many apps and driver-based software. After a deep investigation of the upcoming features, we came to the conclusion that it is impossible to make SPTD driver compatible with the new operating system version and so will stop its support starting from 1903.
    There is a solution that turns on IDE virtual drive but this it requires registry:
    1. Please use the link to download registry file - http://files.disc-soft.com/filer/shared/1558690613/288/. Please double-click it and agree with system warning (this is a standard warning of MS notifying that extra values will be added).
    2. Reboot the PC and you will see the option to create IDE device.
    Don't worry! Be Happy!
