Showing results 1 to 7 of 7
Thread: Disc soft bus keep pc constanly waking up from sleep
    04.10.2007
    108
    Default Disc soft bus keep pc constanly waking up from sleep
    the disc soft bus service keep pc running after go to sleep and wake it up again.
    Only solution is to disable the service and then it cause explorer hang ups.
    is there any solution for this except pc doesnt to use sleep mode.
    Win 10 pro 64 bit
    sptd reg entry used.
    Derb wie eisregen
    hart wie bolt thrower
    und stur wie ein mönch
    Administrator
    SUPPORT1's Avatar
    07.02.2012
    373
    My I ask you to open the cmd and type powercfg/lastwake to see what exactly awoke your PC last time.
    Then please type powercfg -requests to check This will show you the program that is keeping your computer from sleeping. Please, take the screenshot.
    Also, specify what Win 10 version si installed (win+r -> type winver).
    Any latest updates?
    Regarding the DT software. Any images are mounted when your PC goes sleep?
    Don't worry! Be Happy!
    04.10.2007
    108
    I think i solved this
    Sort of
    First i realize that one HDD has massive problem with a logical address therefore i bootet win 7 and run chkdsk on all disk
    Then i check sfc /scannow no problems
    then i rebuild os libraries from online image
    What did i also change, defragmented HDD and chkdsk on an usb drive (simple file check no problems)
    I set disc soft service on manual instead of automatic start.
    powercfg show only lastwake 1 time nothing else .
    i didnt find a history on event viewer
    From there i got the error massage
    A possible solution could be, i repair O&O defrag 17.
    and defrag a HDD (about 50% defragmented, videoediting)
    I could be forced to buy soon a new HDD
    This logical address that constantly must be read again is a sign of death from a HDD or a block address with permission error.
    typical seagate
    next WD purple. i'm done with seagate
    last night i set normal pc into sleep it didnt wake up again.
    Mostly i think it has to do with a mix from read errors and disc soft service. possible with windows upgrade.
    win 10 pro 64 build 19041.329 (20/04) release build may
    last time i called powercfg before today it stands "powercfg /lastwake disc soft service"
    that's my initial post idea.
    and yes i have some images in the virtual IDE and DT drives.
    I knew that Windows didnt allow non WDM2 driver to run on normal mode.
    Normaly i run windows 10 in testsigning mode to avoid most driver issues. i have some old devices, scanner, printer older sata expansion.
    And sptd on for scsi drives.
    All have wdm1 driver self sign.
    But ubisoft easy anticheat must have normal mode on.
    hopefully this was the solution, if not i will post a screenshot of the error.
    Derb wie eisregen
    04.10.2007
    108
    me again it happens again
    Derb wie eisregen
  5. #5
    Administrator
    SUPPORT1's Avatar
    07.02.2012
    373
    Thank you for your detailed description and screenshots.
    So, some images are still mounted while the PC is sleeping, right? Does the problem persist if images are unmounted? If yes, have you tried to kill the disc soft bus service pro service or stop it in Services menu and proceed with the sleep again?
    Also, please, specify the latest installed Windows updates (features, quality, drivers updates).
    And, please provide is msinfo file - http://recordit.co/hRk85POAat
  6. #6
    04.10.2007
    108
    because of driver sign enable (easy anticheat needed it)
    scsi drives are disable
    only one dt drive enable.
    msinfo.zip
    Why winrar not allowed?
    hopefully it helps
    i just disable it to avoid waking up from sleep. Under services
    And the service is manual.
    Derb wie eisregen
  7. #7
    Administrator
    SUPPORT1's Avatar
    07.02.2012
    373
    Thank you for your attachment. We will check the info and contact you with the latest updates.
