Starforce 3.5 and Windows XP x64
    Update drivers - no run on Win64! Old version 3.3, that use other drivers and other numerical key (24) will not upgrade anymore!
    Read this:
    Starforce support team write:
    > > No, the patches are required for all of the games since it is related to
    > > the code changing, not only to the drivers.
    > > Best regards.
    > > Lev Boiarsky
    > > Customer Support Group
    > > StarForce Technologies
    And read this:
    No any comment!
    Before write something, check, how it work!
      Originally Posted by masteryoda34
      Originally Posted by Dochilt
      Solution, install a game using 3.5 or use the tool StarForce Updater
      If you know of a game that uses StarForce 3.5 please point it out. I don't believe there are any right now. Also, updating is not possible because in order to update you need an existing version installed. However, from what I understand, the existing versions of StarForce cannot be installed on Win 64.
      And if there is a game that uses StarForce 3.5 then why should someone have to buy it if all they need from it are the drivers for a different game.
      The buildsignature on the SF file associated with Pro Cycling Manager 2005/2006 (= Radsportmanager Pro) is :
      3.05.007.000, 15.06.05
      That would make it version 3.5, build about a month ago.
      I hope this helps.
        3.05 != 3.5 (3.50)!
          Worms 4 mayhem uses StarForce 3.5.05.03
          Worms 4 mayhem uses StarForce 3.5.05.03, if that can help u.
          Regards, KeDase
