Page 7 of 9 FirstFirst ... 56789 LastLast
Showing results 61 to 70 of 82
Thread: DT Pro
  1. #61
    Fair enough Netsurfer. I know that the customer version will be IDE based soon, and I take it your talking about the IDE jammer or maybe not? Cause thats why I got confused cause Underheaven talked about virtual IDE drive which was my impression was a plugin that would be for the Pro only.
    So IDE jammer for free customer version, and virtual IDE drive plugin for Pro version?.
  2. #62
    18.10.2005
    242
    Quote Originally Posted by Goenk
    that the free version of DT4 will get an IDE-Jammer to prevent the blacklisting.
    that's not true. the IDE jammer will hide optical IDE drives in your PC (like Starforce Nightmare) thus SF, SD & SR protected games will work from SCSI aswell.
  3. #63
    Goenk's Avatar
    12.10.2005
    214
    Sorry Novecento, You're right, wasn't that fit this morning ;-)
  4. #64
    18.10.2005
    242
    np mate, just didn't want any readers here to be confused :-)
  5. #65
    06.12.2005
    191
    Frage Purchase?
    I want to purchase DT but i have a few questions:
    I usually use Alcohol 120 %, can i install dt and use it to emulate and alcohol for backup? or the alcoholґs emulator will disable the dt emulator?
    Alcohol will integrated DTPro?
    Can i purchase now DTPro? In this URL http://www.daemon-tools.cc/dtcc/dt_register.php
    only can purchase version 3.47
    Thanks and sorry for my horrible english.
  6. #66
    Mystique's Avatar
    08.11.2005
    877
    Alcohol will not disable any other emulator like DT, you can use both at the same time like 85% of the users in here
    Alcohol will not integrate DT Pro but the core of DT 4 (correct me if im wrong) and thats why they wont conflict itself (disable emulators etc.)
    But be aware, Alcohol virtual devices are blacklisted on most copyprotections because it uses core of DT 3.47.
    When you follow your link and purchase D-Tools 3.47 you will get DT Pro (Update) 4 free and every new Customer version for free too.
    *Hope everything is right, otherwise correct me*
    sysProfile (Click me)
  7. #67
    06.12.2005
    191
    Default Both?
    Thanks, but both version? x32 and x64.
    I think the best is disable alcoholґs emulator and use dtp emulation.
    I thinktoo that the link of the program to the manual is actually wrong, isnt it?
    Well, thanks for all.
  8. #68
    Default ...
    Quote Originally Posted by Mystique
    Currently no decisions have been made but this is probably what will happen.
    Quote Originally Posted by arisma
    use dtp emulation
    arisma, you mean RMPS emulation?
  9. #69
    Mystique's Avatar
    08.11.2005
    877
    i think he means dtp (daemon tools pro)
  10. #70
    Default ...
    ooooh. This is an acronym I best get used to.
