Mess up Daemon-Tools with Anti-Blaxx? FIXED!
  • #31
    These instructions didnt worked for me .I could not install the newest DT after I had done all you said Djstriker .Same problem with device drivers .Yet I tried to install an older version of DT and it worked .Version 341 .Maybe there is just something wrong with 347 since it really dont get along with Antiblaxx, which I prefer to use? -
    I may just hope that version 4 will cover these problems created by the use of Antiblaxx and deamon tool!
    • #32
      We won't fix problems caused by other software. If you run into problems after using Anti-Blaxx, contact THEIR support.
      • #33
        Just wanted to post to say thanks for the instructions. My sister has had major problems with Anti-Blaxx and DT, all fixed now. Also thanks for the step by step format. Made it much easier to instruct her over the phone.
        • #34
          7) See that nasty bugger that starts out D347....
          I only have these in CSSI driver list so which one i have to delete?
          A347 SCSI Controller
          D346PRT SCSI Controller
          • #35
            Delete this one. Apparently you're using DTv3.46, not v3.47.
            • #36
              Ok I have done this all and it worked.....
              BUT
              Only for D347
              After I installed d347 and tried to upgrade to D400 I got this error :
              This programm will install SCSI Pass Through Direct (SPTD) layer on your computer. Warning - SPTD is not compatible with kernel mode debuggers etc etc etc...
              Any1 knows what is wrong?
              • #37
                Until 3rd party mods are created that are compatible with v4 of DT and DT's uninstaller gets fixed... I wont upgrade my DT and will continue to use v3.xx along with Anti-Blaxx. Since IMO Anti-Blaxx is greatly needed and provides something that DT doesnt currently offer.
                Yeah it sucks having another tray icon (Anti-Blaxx) but its needed and at least for me WORKS.
                • #38
                  Nothing is wrong and that message is not an error. It is an information.
                  • #39
                    Ah ok but after that the system error occures....
                    • #40
                      What error? Complete error message please.
                      • #41
                        System File error
                        • #42
                          lol, that wee bit of info seems important... no?
                          anyways about antiblax... i have had the occasional screw up in DT, although i've always found it easy to repair since AB contain a backup and restore feature... ppl know this right?
                          its just a matter of 'backing up' the settings before hand so that you can 'restore' them later. always worked for me, perhaps not for all though... bumer if it ain't workin for all
                          Athlon X2 3800
                          2gb DDR400
                          6800nu -> 16x6
                          2x160 SATA Raid, 160gb + 80gb + 80gb IDE
                          • #43
                            hello there, what if i cant find the PnP BIOS extension [step 18.]. in mines System Devices i only see 'ISAPNP Read Data Port' which is similar, no others with PNP word there, is this the one? Thanks in advance
                            • #44
                              System File error
                              I get the same error.
                              ALL the reg entries, files and such are GONE when I try to install 4.0
                              Always get that error.
                              • #45
                                OS: XPSP2
                                Mobo: Asus p4c800 deluxe
                                THANKS djstriker91!
                                i reg'd to this forum just to say thanks. anti-blaxx is shit and i cried when it messed up my daemon-tools, but this fix WORKED! yesssss
