Copying Age of Empires III (has SmarteCD Protection)
    Thanks to Nikos...you're, also woks with me...
    Hack The Planet...Save The Planet...
      AOE3 use clone cd
      Forget Alcohol use cd clone - it created image no problem then mounted image - up & running in 3 minutes!
        For protections like Smarte clone cd will work but if you want to make a backup of a Securom >4.8 or Starforce 3 you have to use Alcohol.
          Re: Age of Empires III
          Alcohol is able to make a perfect copy of Age of Empires III; just select the SafeDisc profile. There are 10 read errors in the first 1000 sectors, but they are perfectly readable. Then you can burn a CD without any option enabled.
          Homepage: http://xoomer.virgilio.it/otrebla92
            I've done a backup image of the first Age of Empire 3 disk...
            but, when I want to write this image on a cd it ask me
            what is
            - the track format
            - the block size (2048 - 2336 - 2352)
            - the image header size
            - the image trailer size
            - if data was scrambled already
            - if data contains EDC/ECC info sections
            what shell I select???
            Track Mode 1 - 2048 - 0 - 0 - no - no ?????
              How would we know? Which software and settings did you use to create the image? Usually the image files are created with proper information, thus the writing software won't ask!?
                Iv just tried installing age of empires 3 and rite at the end of the instalation an error message comes up has this happened to n e 1 before???
                  I just bought the game. and was wondering what programs i should Download in order to burn this game properly where i can play it and play online also..
                  programs and steps for each to burn a game would be nice..
                  thanks
                  (i know its alot to ask)
                  and yes i know there are steps thrw out this post. but alot of it is scattered and then some say those or these steps dont work.. type thing.. i just feel scattered when i read it all
                    i need some help!anybody
                    iv tried to copy age of empires three usin alcohol 120!iv tried copying it usin ur recent sergestions but it still isnt workin!workin as in when i put the disk in to play the game it doesnt load up can anybody help me?!?
                      GodSend, I moved your post here. Check out all the information above and report if that helps.
                        here is the esiest way
                        1. Install Slysoft's CloneCD
                        2. Install Alcohol 120% or 52% or Deamon Tools
                        3. Install CCleaner
                        4. Run CCleaner and "cleaner" + fix "issues"
                        5. Backup the game discs with CloneCD using "Read to image file" and "Protected PC Game"
                        6. mount the disc with Alcohol or deamon tools
                        7. install
                        worked fine here
                        in vista x64 to
                          thx for the info ....
                            Smarte protected cds are quite easy to copy.
                            as nikos said just use the safe disc profile to copy.that should do it
                            or
                            you can also use an iso image making software with read error ignore enabled
