Page 2 of 7 FirstFirst 1234 ... LastLast
Showing results 11 to 20 of 70
Thread: Star Wars: Battlefront 2
    Methadon's Avatar
    10.10.2005
    516
    Quote Originally Posted by Dllfile
    Since when do you have to know anything about a file type to create one, especially when using a program that does just that? you can purchase Alcohol 120%, not know anything about the file types it uses, makes an image of your CD/DVD and yet, still know nothing about the files it made...
    I was talking about the file not the filetype.
    But he says "thats all i know bout the file", usually you know how you created the image, which profile, speed, etc.
    I don't know if he mean if thats all he know about the file or filetype, I probably was abit forward.
    Of course you don't need to know anything about the filetype to create one.
    04.11.2005
    4
    I can't get this backup to work I tryed a number of programs to hide deamon tools but it gives me this error "A required security module can not be activated. This program can not be executed." Maybe bad copy it was done with Alcohol 120% and has a mdf file any other ideas?
    I fixed the game to work through SecuROM at my friend's computer.A little bit of hacking throught the registry base denying read access to Administrator on MountedDevices and Scsi ports...
    The thing is when I did at my computers the thing isn't working.
    So now I have to punch my beacuse I've wanted to play the game for a very long time
    I've heard the new Anti-Blaxx can work around SecuROM
    Methadon's Avatar
    10.10.2005
    516
    Quote Originally Posted by RyXXed
    Don't use Antiblaxx, only problems comes with that app.
    i tried it and it doesnt work.
    what can i do to make it work (i tried also with scsi ports and MountedDevices)? I am using Daemon Tools v347 and Alchochol 1.9.5.
    It worked at my friend's computer and it won't work at mine...
    Use sr7stop or sd4hider or virtual cd hide.
    I use Anti-Blaxx sometimes, if there is no other way, but i've only one bad experience with Anti-Blaxx: I got a BSOD while i was playing and so Anti-Blaxx don't renamed the files back (and the registry things).
    So i had to remove the dt and Alcohol driver manually.
    this might be a dum question but where can i download sr7stop?
  8. #18
    One of many sites:
    http://cdmediaworld.com/hardware/cdrom/cd_utils_8.shtml
  9. #19
    i download the sr7stop and it says "Nothing to hide"
    I mounted the image on Alcochol and daemon tools
    please help i need to play the game
  10. #20
    13.10.2005
    334
    Are you logging in to Windows with admin rights?
