Page 3 of 7 FirstFirst 12345 ... LastLast
Showing results 21 to 30 of 70
Thread: Star Wars: Battlefront 2
  1. #21
    Yes of course.
    But it doesn't matter now i fixed it.i found the solution in the SecuROM 7 sucks topic by Lord_Duke (the .bat code)
    It works excellent but i did also this :
    changed the device parameters to default (generic, dvd rom, 1.0)
    Emulation set to only SecuROM
  2. #22
    13.10.2005
    334
    Quote Originally Posted by RyXXed
    Hmm? Why?
    That's irrelevant. The Securom emulation in Daemon Tools has absolutely nothing to do with current versions of this protection. It's for old securom that utilized subchannels. These days, securom doesn't use subchannels at all.
  3. #23
    Default Please say it clear
    Someone plz say in steps what to do ifm you get the error "A required security module can not be activated. This program can not be executed." thanks mates
  4. #24
    @nikos Why? I don't know I thought it'd work if I do that
    @battlefront
    Mate, it's the same thang like this hack with secuROM *new* v.5.3.xx.
    If you wanna run your copy with DT, you've got to do this:
    permit access on two registry keys
    play the game :mrgreen:
    I recommend the subINacl Method, so you can easily run the hacks with a *.cmd file.
    Furter steps
    Download the mini App from the resource Kit at http://www.microsoft.com/downloads/d...displaylang=en
    Then Install
    Copy the following text into a *.txt file and rename to *.bat or *.cmd.
    Code:
    "D:\XPAPPS\TOOLS\MAINTENANCE\ResKIT\subinacl" /keyreg "\HKEY_LOCAL_MACHINE\HARDWARE\Devicemap\SCSI\S CSI Port 2" /deny=administrators=r "D:\XPAPPS\TOOLS\MAINTENANCE\ResKIT\subinacl" /keyreg "\HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices" /deny=administrators=r PAUSE
    BIG note: of course you have to change the pathes the the subinacl and maybe the SCSI Port 2 is not the right for you.
    Check that out.....
    Execute the Batchfile ....& have phun.
    BTW.: Image was dumped with Blindwrite v.4.5.7 ... but the lousy EMU App ALC120 should also work. :P
    Cheers
    It worked for me
  5. #25
    Quote Originally Posted by Nikos
    Hmm? Why?
    Nikos you could have been a little nice when telling RyXXed that the setting he was using was irrelevant. Maybe 'that setting doesn't work' instead 'that utterly completely useless pitiable and outdated setting' ( )?
  6. #26
    13.10.2005
    334
    I was gonna say that the default names might result in blacklisting problems with other games, but then again, changing the defaults to something else is so common that copy protections might not even bother anymore to blacklist the defaults.
    Are you looking at me? ARE YOU LOOKING AT ME???!? Huh!? PUNK!!!!??
    Actually, BW uses this Patin Coffin (pun intended) stuff. And "Autoplay". So it's emulation too. And I'm sure you already know that.
  7. #27
    13.10.2005
    334
    Quote Originally Posted by JoelEllison
    Or maybe "no push button, no work". Anyway, "irrelevant" isn't impolite. Well, I'm not a native english tonguer <g>, but I'm quite sure "that's irrelevant" was the only phrase to describe the situation in just three words (or does "that's" count as one word?)
  8. #28
    04.11.2005
    4
    I got it to work with SR7.Stop_1.0 but it won't play online. No matter what serial number i put in it won't let my play. Does anyone know how to fix this?
  9. #29
    13.10.2005
    334
    Quote Originally Posted by ReD RyU
    May I ask where you got the CD-key/serial number from?
  10. #30
    1
    Hi to everyone i need help with Battlefront 2. I tried with everything and i canґt play it i have a different error everytime. Firs i used anti-blaxx and it said something with the protection. Later i tried with the SR7.STOP and it said that i change the backup CD and insert the original. I used SR7.STOP with anti-blaxx and it said that i change the CD/DVD of Battlefron 2 to the F:
    їїїїWhat Should i do?????
    Sorry for my english
