Page 1 of 3 123 LastLast
Showing results 1 to 10 of 29
Thread: How often do you reinstall your OS???
    Default How often do you reinstall your OS???
    Hi!
    I just wanna know how often one reinstalls his/her Operating System, whatever that may be.
    So, mother goose has been messin' around in your egg salad, huh kid?
    Methadon's Avatar
    10.10.2005
    516
    I do it around every other month, it is not a rutin that I've got.
    I guess I just like a new fresh OS install, everything runs so smooth and nice.
    On my C drive I only have my OS and my software installed, I doesn't store anything else there.
    I just copy my software configs and my bookmarks to another disc, that's all I need.
    Same here. I usually don't copy any of my bookmarks. Don't know why, I just don't do it. I should do that. Only the installed OS and that's it. Fresh install: format partition and kabuum, new OS in 15 min! Sometimes I use DriveImage or Norton Ghsot(same thing really).
    Methadon's Avatar
    10.10.2005
    516
    Quote Originally Posted by kukubau
    Without my browser bookmarks I would be totaly lost on the net.
  5. #5
    07.07.2005
    384
    Only when the OS is screwed. My pc is a family computer , so I can't do it regularly. Even if i could, i wouldn't. too much hassle, installing everything. only 1 hd is worth using in my pc, my other hd is too slow to copy all our work and stuff.
  6. #6
    Last time - after I've changed motherboard. It's not a big deal to reinstall OS, but installation and configuration of all other software requires too much time.
  7. #7
    I don't do it monthly but often, all 3-4 months.
    Windows gets so slow if you have much apps installed and after 3-4 months there are always other problems with windows.
    After reinstalling it works very fine.
    I've also only windows and the installed apps on C:, on D: there are "My Files"(documents, music, installations of apps....) and on my external i've my images and some games installed.
    So it takes not much time to reinstall and renconfigurate windows.
  8. #8
    Kinlaadare's Avatar
    24.05.2005
    697
    The less the better... and usually when I have to reinstall, I reinstall 3 OS : 2 xp 32b (one for burning & imaging, and one for leisure) and one 64b (work). I hope vista will solve that sort of problem (M$ said it will... wait and see )
    Carpe diem
  9. #9
    Default Re: how often backup?
    I haven't reinstalled since 2003. I make regular backups. Maybe you should ask how often do I restore my OS? I'd say about every 6 months. However I just had a hard drive failure so I'm in the process of going through all my files.
  10. #10
    Dllfile's Avatar
    27.03.2005
    220
    Depends on if the system is having probs, unstable, or seems slow and any tweaks I have applied after going back and trying to "re-tweak" it as well as do automated cleanups using batch files ect.., if it still just seems a bit on the slow side, I just pop in my custom restore disk made with DriveImage. and in a couple mins, back to how I had it when I first installed cept minus the sound and video drivers This way I can choose to install a fresh clean driver install.
    I use another PC to store anything I want to keep such as bookmarks, ect.. Then its as simple as copying back over once I get the OS Restored and drivers installed. System is already pre-tweaked, cept drivers like nVidia of course.
    All in All roughly 10 mins and I am back to a fresh install with drivers.
    Then comes the longer part, deciding what programs I want to install or what games.
    Lately, I have been doing it once a month the past few months now, but normally, 3-4 months.
