X3 Reunion - Using a mounted image
  • #46
    Anyone else experiencing reboots during the game copy protection check right when you start the game? It happens to me randomly and I cannot figure out what is causing it. I did read other peoples issues with reboots with SF checks though.
    • #47
      Your question seems to be answered with your own post here. This should be fixed in the next version of DAEMON Tools.
      • #48
        Originally Posted by evolart@hotmail.com
        I got X3 reunion working great using DT4 and this method: http://www.daemon-tools.cc/dtcc/show...ht=right+click
        This requires a SATA HD to work properly. I setup DT4 with all copy protections and then disabled all PATA devices via Device Manager. Then I loaded the image into DT4, installed, and played with absolutely no issues.
        NO WAY!! IT WORKS! I"ve been trying for a month reading on various sites how to bypass Gayforce and now it works!
        1. Disable PATA in device manager
        2. mount on DT4 w/ no emulations
        3. play!!!
        • #49
          i have a nforce 4 mobo
          and under ide ata/atapi controllor
          i just have "nvidia nforce4 parallel ata controllor"
          do i just disable that?
          thank you
          • #50
            thank you
            If thats the only thing you see then you have your harddrive and your dvd-drive are using one parallel cable. Disabling that would crash your computer (obviously because they're on the same cable). You need to buy a SATA (serial ata) harddrive for the trick to work. So in your device manager, you would see:
            -nvidia nforce4 parallel ata controllor
            -nvidia nforce4 Serial ata controllor
            And you would just simple disable the PATA one...
            I tried Splinter Cell - Chaos Theory which is Gayforce as well and it works too.
            • #51
              i have sata hdd =) 2 raid 0 and 1 just normal. i only see "nvidia nforce4 Serial ata controllor" in scsi and raid controllor and in there i have the following:
              ->D37PRT SCSI Controller (daemontool 3.47 i think, didnt want to update cuz 3.47 runs fine )
              ->Nvidia nforce(tm) raid class controller
              ->nvidia nforce serial ata raid controller
              • #52
                X3 on a laptop?
                It seems from what i have read you need to remove the power and IDE from optical drives to get this to work with emulation but i cannot do this on a laptop, tools like SFnightmare seem to do nothing, is there anything i can do? any sugestions are apriciated many thanks in advance.
                • #53
                  Well i can't even make an image of X3, cannot get DPM info using current device
                  Strange as i've made good images of GT Legends & Worms Mayhem
                  Oh well
                  • #54
                    As mentioned in many threads before, you have to clean your system from the starforce drivers because they prevent making a correct DPM measure.
                    Try to clean your system with sfclean.
                    • #55
                      Yes i realise this, and as mentioned in my post i've made images of GT Legends and Worms Mayhem. Both of these are starforce. Got hold of a new DVD drive today and it has created the image with no problems getting the DPM, now i've just got to try to run it.
                      • #56
                        Originally Posted by sin316
                        install dt 4 (properly !)
                        What is properly? (and what way is the wrong way?)
                        unplug optical drive/s (cd/dvd drives)
                        You gotta be kidding... god I hope they go out of business.
                        • #57
                          I doubt Starforce is gunna be evaporating any time soon. I mean think about it, any game that forces you to unplug your drives so you can play a copied version must have really good copy protection right? If we gamers were making the games, we'd probably use it too so we could get $$$. It's all about the green.
                          And on that note, I need to go plug my cd drives back in; I wanna play ut2004 but I gotta install it first :/
                          • #58
                            I was hoping for companies who use it to go out of business - but the more popular Starforce gets, the more people are going to hack at it.
                            Also, I thought that was interesting, if you hold shift down when you start the game you get a box where you can enter a keycode - that will bypass security and start the game. You get such a code from the people at Starforce if they believe you are worthy - and it only works for your machine.
                            Amazing though that nobody has made a generator for that - guess you are right, it is a tough program
                            • #59
                              Hi everyone, the info here helped me a lot. I've got X3 working now by unplugging IDE.
                              Can anyone using X3 w/o cd confirm that it still works after 1.3 patch, I've heard rumors about updated starforce protection.
                              • #60
                                It runs fine with me. Nforce 4 board with pata disabled and sfn, disable cd disable node.
