Page 8 of 10 FirstFirst ... 678910 LastLast
Showing results 71 to 80 of 93
Thread: X3 Reunion - Using a mounted image
  1. #71
    Daumen hoch update D-tools
    I updated to DAEMON Tools 4.0.3 X86
    Heres a link.
    http://www.daemon-tools.cc/dtcc/down...Download&id=81
    I then installed X3 Reboot as instructed.
    I then updated to V1.3.
    I then disconnected any drives(just pulled out IDE cables)
    Then played the game.
    NO STARFORCE WORKAROUND.
    Easy Peasy.
  2. #72
    03.07.2004
    19
    Quote Originally Posted by shane007
    Easy Peasy.
    Having to pull out the cables is not easy peasy thats a damn nuisance.
  3. #73
    11.01.2006
    4
    i have a problem.. when i try to open up CD1 to install the game. it says error in command line.... anyone know how to fix this problem?
  4. #74
    cyberakuma222, you agreed to abide by the rules which state you shall not double post, or otherwise be banned. Keep the discussion of your problem to this thread.
  5. #75
    21.02.2006
    6
    it's possible to play X3 with AMD64 , nForce4 , daemon 4.03 ??
  6. #76
    21.02.2006
    17
    Well, I installed the game from an Alcohol 120% image, mounted it in the last version of DT and worked without problems. It passes StarForce protection and I can play perfectly. I don't have a DVD in this PC, I made the image in another computer. Maybe that's the problem, having a DVD in your machine?
    My specs are:
    AMD64 3200+
    GeForce FX 5200 256MB
    1024DDR 400MHZ
    Motherboard ASUS X-series (don't want to look for the right number)
    It works smoothly most of the times except in heavy asteroid populated area. I use the LessRoids mods now and it works great.
  7. #77
    21.02.2006
    6
    Unglücklich
    I have LG Combo DVD\CD-RW. And I have a "CRC Data Error" when i'm trying copy image from DVD to my hard disc, but only when im using my DVD\CD-RW.
    My spec:
    ASUS K8N4-E DELUX
    AMD64 3000
    GEIL 1024 400MHz
    SAPPHIRE X800 GTO2
  8. #78
    Default Myyyyy Wayyyyy !!!!!
    i've just disabled from hardware list of windowsXP my IDE/Parallel Controller and it works .... grate game !!!!:wink:
    when you have finished just enable your controller again
    my system:
    -XP Professional
    -DT 4.03HE
    -1xBurner ide
    -1xReader ide
    -2x160 S-ATA
    -Athlon64 x2 3800+
  9. #79
    Default Problems
    I actually get passed StarForce Protection and choose "Start X3" but all i get is a black screen for a couple seconds and then an error message. Does anyone else get that? How do you fix this?
  10. #80
    @Sarutobi
    And what is the error message?
