"System File Error" when installing 4.0
  • #31
    Originally Posted by DeGier
    This is what I get :
    This program will install SCSI Through Direct (SPTD) layer on your computer.
    Waarning - SPTD is not compatible with kernel mode debuggers (soft-ice,Windbg etc.!)
    Then I continue and I get the System file error
    XP SP2
    Symantec antivirus 2005
    word by word happenings with me......I also have norton antivirus 2005 still had that problem
    • #32
      I have the same problem
      I run windows 2000 service pack 4, with AVG anti virus free editon and peer guardian. The error is when I run Daemon tools v4 it say me what it say to all the people about SPTD. What's wrong?
      • #33
        I personally think this is due to norton antivirus 2005
        • #34
          Don't think so. I don't have Norton Antivirus.
          Here are the images so that the administrators can understand what is happening. After the reboot this is what appears.
          After pressing OK the next image appears after that the installation crashes.
          • #35
            Get the same error message.
            Not got NAV installed either
            • #36
              Have any of you tried disabling your AV temporarily to see if that allows it to work?
              • #37
                I get the same error.
                Things i tried:
                -renamed/removed SPTD.sys.
                -Disconnected my IDE drives.
                -Removed my Antivirus ( nod32 ).
                Nothing helped.
                OS: WindowsXP SP2
                • #38
                  I have the same probleme,
                  I removed antispyware and antivirus.
                  Still not morking ...
                  I use WinXP SP2.
                  • #39
                    system file error
                    I have the same probleme and disabled AVG antivirus.
                    I also uninstalled the antispyware Spybot.
                    Any solutions ?
                    I'm desesperate.
                    • #40
                      I have the same problem.
                      I tried rebooting into safemode, removing the sptd.sys and then installing, then rebooting. No luck. I then tried doing it again by removing it, installing, removing it again before rebooting and then going on again, but no luck. I did notice that the driver interferes (seemingly) with the scsi miniport driver for my internal usb card reader because when sptd.sys is actually installed I can't see any of my removeable devices. I'd say the install has the basic characteristics of an infinite loop under some specific circumstances because it keeps going through the same routine over and over. It doesn't seem to realize it has installed the miniport driver. BTW, XP SP2, Avast AV, Zone Alarm.
                      • #41
                        same problem,
                        I disabled my antivirus, and removed my antispyware.
                        still not working
                        • #42
                          "Internal Setup Error"
                          When I tried to install after the reboot I got the "Internal Setup Error" error.
                          I then removed the sptd.sys file that you are talking about and restarted the computer. I then ran the setup again and it installed the SPTD. When the setup wanted me to reboot, I rebooted the computer into Safe Mode and ran the setup there. No error message came up and when I then rebooted the computer into normal everything worked just fine.
                          I hope this will help someone
                          • #43
                            Now the install wont even start.
                            3.4.7 works fine but as soon as i start the 4.0 installer i get this message:
                            -Deleted everything in the temp map.
                            -Searched the register for daemon and d-tools and deleted everything.
                            -Used CCleaner to clean the register.
                            -Tried to start in safe mode but still get the same message.
                            • #44
                              I installed it in safe mode but when i reboot in normal mode, DAEMON-tools tells me STPD is not installed!
                              I have the SPTD.sys and the SPTD7331 (or something like that).
                              Help me, im desperate!
                              • #45
                                What problem keeps you from installing in normal mode
                                What problem keeps you from installing in normal mode?
