My experience with V4 and several new games:
  • #31
    omg it just keeps going from bad to worse, i did install it with the origanal and tries to make it work but then it said the same thing as the mounted one.omg!
    • #32
      Sounds like your original copy is bad or the CD key provided is inaccurate. I'd suggest taking it back and getting a different one if you can, or else try contacting the developer's support.
      Arb
      • #33
        Im having problems posting so this post may seam off topic in this subject but I hope to catch an adminstrators attention and maybe help others with some problems with Daemon 4.00. One conflict I noticed was with my anitvirus, had to uninstall it it b4 installing Deamon, and the other conflict was with Microsoft .net frakework 1.1. Hope this helps
        • #34
          Originally Posted by germx
          And NFSMW works fine 2, and so does X3 and so on :P
          hey NFS you just mounteed the disc 1 and played without sd4 hide???
          just wondering cuz i need to use it so if you didnt can you tell me what did you do?
          Yossef A. Ben Mikhail
          MCSA MCDST
          any mevin ivrit.
          • #35
            Ubisoft and Codemasters make a contract: all the games in
            the future has Starforce protection... Don't know what the
            correct date of this,also i heard Prince of Persia:Two Thrones
            will Securom 7 yet, but this is not sure. We will watch next..
            • #36
              Use SD4Hide or disable your drives.
              • #37
                I got King Kong with following steps to work
                1 ) Make an perfect 1:1 copy of that Game
                2 ) Unpluged your IDE - Drives
                3 ) Turn CD and Node off with SFN
                4 ) Mount it with DT4 and before that turn RMPS on !
                5 ) Install
                6 ) Ready to play !
                I am your father
                • #38
                  It's a bit weird, sometimes I use sd4 hide and it won't work, then I restore it, hide it, restore, etc. And it doesn't work the first time, but when I start it again it just works. And I even got it to work after a restore.... Weird stuff.
                  • #39
                    well i got the same prob and i restart my box and use sd4hide an everything works fine but sometimes its stuck for no reason
                    MCSA MCDST
                    any mevin ivrit.
                    • #40
                      hi
                      merciii very much
