Page 4 of 6 FirstFirst ... 23456 LastLast
Showing results 31 to 40 of 57
Thread: Unable to set new drive letter under Vista
  1. #31
    Quote Originally Posted by PlatoSG View Post
    I just got it working using the drivers in WIndows\System32\drivers for Vista but you have to find a cdrom.inf and put it in their and make sure cdrom.sys is in there as well. Then go to Device manager if there's no drivers installed for the SCSI Virt drive which was my problem, it's under Other Devices in the list. Click it and update the drivers - browse to Windows\system32\drivers and install them from there. And then wait a few mins and the drive letter shows up auto.
    Mike.
    thanks. i found the driver but couldn't install it. i googled around and it looks i need a reinstall of the whole system.
  2. #32
    Idee FINALY AN AWNSER ^^ (wel it worked for me :P)
    I had same problem as described by several people above and was (as you can imagine) pretty annoyed. And after some struggelin i might have found an awnser everybody can use
    (You don't need to uninstall deamon tools)
    First go to the normal download site of daemon tools
    Disk-Tools.com - Published Software Download
    now comes the important part.
    download the SPTD at the bottom of the site. (make sure you get the right version for your 32 or 63 bit system)
    click on the SPTD file to open it...
    Seeing that you all had daemon tools installed there will be 3 options you can click on.
    I believe they are. Update, Uninstall and Cancel.
    Click on Uninstall
    Restart system.
    Then click on the SPTD file again where you now have the options Install or Cancel
    Install and then restart again.
    Start daemon tools and now you probably have disk letters again
    (looking at that the SPTD install is included in the daemon tools install file you can also uninstall the SPTD and after that deamon tools reboot and then just install deamon tools normally, this should work as well )
    hope this helps some people (A) it did for me
  3. #33
    You need to copy and paste the *.inf and *.PNF files from this folder:
    Code:
    C:\Windows\System32\DriverStore\FileRepository\cdrom.inf_b2045cb8
    AND THIS FOLDER:
    Code:
    C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_1d87dda2
    to C:\Windows\inf
    the *.sys files in those folders may be required to be copied and pasted into \System32\Drivers if not already there.
    Now you need to go to device manager and right-click on the not working virtual driver which is probably now under other devices. Select to update the driver and now point to C:\windows\inf
    should work fine now!
  4. #34
    07.08.2008
    2
    Hi, I've tried everything I have seen in this thread and I cannot get it to work. Whenever I try to update the drivers I get an error message saying it failed to install the driver (CD-ROM), the message under that is "Access is denied."
    Any help would be appreciated.
  5. #35
    You are working with administrator permissions?
    07.08.2008
    2
    Actually, I solved my problem. It wasn't related to a daemon-tools issue. But, in case anyone else has this problem at some point, here is the solution (I have no idea what caused it).
    The problem was that I was no authorized access to the files the system needed to install the driver. So, to fix the problem I went into my registry (regedit) and gave myself Full access to everything in the Local Machine folder. This did not solve the problem. It might not even be necessary to do this.
    Earlier I had come across a reg file that adds a little option in your right-click menu to take ownership of folders and files, found here Take Ownership of file - Vista Forums. Using this I took ownership of the following folders:
    windows/inf
    windows/system32/drivers
    and then the next time I tried to install the driver for the virtual drive it was successful. I don't know what caused this to happen, but if anyone else experiences something similar, hopefully this post saves you the 4 hours it took me. =)
    -Koney
  7. #37
    Default SOLVED: Vista x86 Business, SP1
    I had the "no driveletter - can't change drive letter" issue.
    However my cd/dvd-player was visible in Device Manager but they had a yellow "!". The Device driver could not be loaded.
    I used this guide -> PC Hell: How to Fix Error Code 39 with DVD or CD-ROM drive in Windows XP/Vista
    Very easy and after the reboot, I had access to change the drive letters and everything is working again!
    Great Sticky this one!
    Regards
    //David
  8. #38
    Hello together
    I have a problem that could be related to this:
    under vista 32 i can change the drive letter without problems and while the sessions lasts, everything is fine. But after a restart the letter is again the first free letter (e.g. D.
    This is also happens when i close Daemon Tools Lite Tray Icon, starts it as Administrator and change the letter in this way. After a reboot, the letter changed again.
    Could anyone help?
    Thank you
    steven
    the problem is the same as in this thread, i think:
    http://www.daemon-tools.cc/dtcc/f19/...letters-19144/
    but i use official vista sp1
  9. #39
    16.10.2008
    1
    Quote Originally Posted by KiwiWifi View Post
    Regards
    //David
    Thanks a lot for that link, worked like a charm.
  10. #40
    i have the same problem. i have windows vista and after i installed it abd restarted my computer. it says "the application has failed to start because its side by side configuration is incorrect.please see the application event log fot more detail"
    please help.
Tags for this Thread
