Page 1 of 5 123 ... LastLast
Showing results 1 to 10 of 43
Thread: Daemon Tools 4.0 and awxDTools
    Does anyone know of any way to get awxDTools working with the new version?
    Is it already working for any of you?
    Is there any comparable program out there that will allow right-click mounting with the new version?
    Thanks!
    You've to wait for v4 compatible version of 3rd party add-ons.
    17.11.2005
    6
    I'm going back to the version prior to v3.47.
    awxDTools IMO is a NEEDED feature that DT needs to incorporate. Why? Mounting images over a network that are multi dirs thick SUCKS. But having a right click/mount feature kicks ass!
    20.04.2004
    4
    already did
  5. #5
    You already did what, waited or gone to 3.47?
  6. #6
    07.07.2005
    384
    use .bat files to load your images.
  7. #7
    Quote Originally Posted by al1uk
    what kind of bat / what command lines do you use ? can you give some samples like to mount/unmount on a drive ? thx
  8. #8
    Quote Originally Posted by rip_pit
    Look into DAEMON Tools Help:
    http://www.daemon-tools.cc/dtcc/daemonhelp.php?helppage=16#commandlineswitches
  9. #9
    07.07.2005
    384
    I use this to mount Far Cry mini image:
    FAR CRY - MOUNT PROCEDURE
    cd C:\program files\daemon tools\
    start daemon.exe -mount 0, "C:\documents and settings\administrator\my documents\Games\farcry.mds"
    Unmount Procedure:
    FAR CRY UMOUNT PROCEDURE
    start daemon.exe -unmount 0
    You have to set at least one vdrive for this to work manually via dt, and also uncheck secure mode. if secure mode is on, the it'll ask for confirmation everytime.
    match the program folder to the same as your pc, and the file paths.
    more info here: http://www.daemon-tools.cc/dtcc/daem...ndlineswitches
    NOTE: im only using this until a new version of daemon script comes out.
  10. #10
    07.07.2005
    384
    Quote Originally Posted by AnalCobra
    The help file isn't 100% clear.
