Need for speed Most wanted
    I have some huge problems too
    I mounted my .cue and .BIN files with DT4 and Alcohol 120% used sfn s4 sd41.1 aswell as anti-blaxx and NONE of thme works, everytime I try it says please put the right dvd in the device or w/e help me please
      @arsenik012
      Recreate your Image with Alcohol 120% (Safedisc 3/4 profile) and then try it with safedisc 4 hider.
        Blazkowicz is right, the .cue/.bin format does not store enough information for the copy protection to work. So basically your images are worthless and you need to create new images with Alcohol 120% using your original CDs.
