Showing results 21 to 30 of 36
Thread: device setup error: code 25032
  1. #21
    Administrator
    06.11.2002
    2,044
    Before you press ok, please watch in the device manager - what unknown device you have and its status?
  2. #22
    05.10.2003
    9
    Default Virtual SCSI Drive not detected; error codes 25001 25032
    Operating System: Windows 98 SE
    Burning Software: Easy CD creator (uninstalled thoroughly)
    feurio, CloneCD
    Anti-virus Software: AntiVir
    DAEMON Tools Version: 3.41
    Installation terminates with error codes 25001 and 25032. After installing again virutal SCSI driver cannot be found.
    In the device manager there are two unknown devices in folder computer-->system device-->unknown device. Removing them and reinstalling dt does not help.
    Used feurio to detect driver conflicts and installed new Aspi driver: does not help either.
    Same problem with Alcohol120.
  3. #23
    Administrator
    06.11.2002
    2,044
    ASPI driver is irrelevant for Daemon/Alcohol absolutely, they don't need it.
    Delete all unknown devices and reboot. Then try to run setup - when you get 25032 - DON'T do anything! Immediately go to device manager and check what is there and with what status.
  4. #24
    05.10.2003
    9
    Directly after error code 25032 (0x61C8)
    (0x0) there is only one unknown device (with exclamation mark) and the status is: no drivers installed (Code 28).
  5. #25
    Administrator
    06.11.2002
    2,044
    You have smth either with antivirus (try to disable it) or Windows file protection. Do you see pnpshark.inf in the WINDOWS\INF folder?
  6. #26
    05.10.2003
    9
    Sorry, AntiVir doesn't seem to be the cause/curse and no pnpshark in windows/inf.
  7. #27
    Administrator
    06.11.2002
    2,044
    3.41 setup copies this file to Windows\inf folder. Check it good BEFORE you press ok after error (after you press ok setup will rollback and delete it).
    If you still not see it - then problem is with Windows file protection.
    Addition: as you use 98 then file protection has nothing to do here (it is in ME only)
    in this case i have no idea what's going on.
  8. #28
    05.10.2003
    9
    Before pressing Ok, pnpshark is there, indeed
  9. #29
    Administrator
    06.11.2002
    2,044
    Do you see the dialog of Windows rebuilding driver list during installation?
  10. #30
    05.10.2003
    9
    Yes
