On my Intel board, disable in BIOS works :)
  • On my Intel board, disable in BIOS works :)
    Hi,
    On an Intel 915 board (using 2 SATA drives, 1optical),
    I have been able to just disable the PATA controllers in BIOS, and DT4 works. Tested with CIV, will report if any other problems come up.
    (The PC is tucked under the desk, much easier to go the BIOS route then open up and unplug).
    Hope this helps,
    Bye
    Hi,
    X3 , no prpoblems
    (Using the shut-off in BIOS)
    DT4 works like a charm. I can now put my valuable originals away for safe keeping.
    Bye!
      How did you disabled those controllers? I have an ASUS P5DA2-E premium motherboard but i cant find how to disable the controllers...
        Originally Posted by d4lover
        Hi,
        Hope this helps,
        Bye
        can you tell me wich values please! I have the exact same MB
        help me please tell me wath to disable ...
