Page 2 of 8 FirstFirst 1234 ... LastLast
Showing results 11 to 20 of 71
Thread: Need For Speed Most Wanted problem!
    Methadon's Avatar
    10.10.2005
    516
    Quote Originally Posted by Termin
    but its not a big deal, then i just have to use my original DVD, as long as the game works i am happy :P
    Have you tried using sd4blocker or have you tried if it works if you disable your drive through device manager.
    16.11.2005
    12
    It works perfectly for me without win200 trick. I only have to disable IDE drives with SFN. Maybe your image is corrupt or the problem is not due to DT
    Ausrufezeichen Help Me
    ok, im not sure what to do, didn't read the forum all to carefully but u guys sound like u know what to do. I used DT to intall NFS MS from 4 .mdf files. now that i have it intalled it askes me to insert CD-ROM, what image and how should i load it on DT.
    feel free to email me about this.
    Just mount disc one to play. Use SD4Hide or starforce nightmare for antiblacklisting.
    www.cdmediaworld.com/hardware/cdrom/cd_utils_8.shtml
    Reden Help Me
    thanks for the reply, works great now
    08.12.2005
    2
    Cool Restricted User Account
    Is there any way to run Need for speed Most Wanted without the DVD with an image as a restricted user account?
    I mention that I used Daemon Tools with a maxi image of the game but any kind of Speed load work only as Administrator.
    Is it possible that Daemon tools succeeds to be the only tool (without Safedisk hider and the others)?
    Quote Originally Posted by remuss
    You can unplug your optical IDE drives or put them on an additional IDE controller (you can get those for $20).
  8. #18
    use this to play.... use SAFE DISK 4
    and u must have only one Virtual CD with the Cd1 monted...
  9. #19
    18.11.2005
    24
    I am using 4 virtual drives all at the same time with 1 mounting the need for speed cd 1. To play I use safedisk4 hider 1.1, and the game works, even with patch 1.3
  10. #20
    08.12.2005
    2
    Böse Digging
    It seems that the speed.exe is spawning another executable (a Macrovision Cleaner) in user's temporary folder. And the user is not allowed to execute programs outer Windows or Program Files folders. So it seems that it's not a Daemon Tools question but a devil's protection scheme.
