Showing results 1 to 5 of 5
Thread: Question on DVD Device
    16.11.2002
    6
    Default Question on DVD Device
    Well I see a DVD device in the Device manager. There are no (!) next to it. The Drive name is:
    Generic STEALTH DVD SCSI CdRom Device
    And the SCSI Driver is listed as:
    ST323DK SCSI Controller
    When I check props on the drive there isn't a driver loaded???
    Is there one I can download and install?
    Thanks,
    -Ed
    What is the problem? If you want a dvd-drive, right-click on the daemon tray icon, click virtual dvdrom, and click number of devices, and pick number.
    Administrator
    06.11.2002
    2,044
    Try to select standard CDROM driver in device manager. It is specified in cdrom.inf supplied with OS.
    16.11.2002
    6
    Default Errors
    When I mount the drive I do not get a Drive letter. Nothing shows in Windows Explorer or My Computer.
    Then when I go to unmount the image I get an "Unable to Unmount Image. Unit is locked" error.
    I saw in a post some had the same issue they installed a DVD-ROM driver and it fixed the problem???
    Thanks,
    -Ed
  5. #5
    Administrator
    06.11.2002
    2,044
    Can't you read what I wrote above?
