Showing results 1 to 10 of 10
Thread: Burning MDS/MDF format games
    03.12.2005
    20
    i just got a question...assumin' u have a game that is MDS/MDF format...is there a point of burnin' it? coz lets say it's chaos theory...it would only be able to bypass SF if u play it as a image file using dt..instead of burnin' on to a cd and play it with ur opt drive rite?
    may be a stupid question...
    sorry in advance lol
    You can burn (RMPS needed) it an put it into an usb drive.
    Then deactivate your ide-drives. Or if you have an RAID Controller it would work, too. Or an nForce 3/4 mainboard.
    i still dun get wat these mdf files are specifically for tho...
    so i have to burn them in order to make the game work?
    Cool
    Quote Originally Posted by aspexx
    If the MDS/MDF img is a DVD img then burning is definetly not work. CZ dvd burner is not advence as cd burner. And if the img is cd then there is a chance. find a software which patched the MDS file (Google is ur friend):wink: and from the software menu choose ur best cdr then write those patched img using alcohol120% and select securom new profile. If u done correctly then this copy definetly work.
  5. #5
    03.12.2005
    20
    wait if i burn it on cd...it would work on ide drives if i have nforce3/4 mbs??
    Athlon64 3000+@2.6GH, DFI NF4 Ultra-D, 1.0G OCZ(2-3-2-5), Asus Radeon X800XL
  6. #6
    Default ...
    If you know what the purpose of an ISO file is: MDF/MDS files serve the same purpose (except the new format can hold more specialized copy protection related information).
    hxxp://en.wikipedia.org/wiki/ISO_image
  7. #7
    03.12.2005
    20
    oh alritez..i c thnx alot
  8. #8
    You are right, there is no point in burning it. (except 4 the USB drive method)
    You can't write a RAW( Raw basically means ALL the info on a disc) DVD image yet, so it can't be a 1:1 clone like cd's can.
    So while we wait for the technology, you either have to mount your DVD images, or get a USB drive to burn 'em.
  9. #9
    03.12.2005
    20
    hmm yeah that clears up a lot of things...well i learned somethin' haha...i didn't know u still can't make 1:1 clone for dvds...ty
  10. #10
    Default DVD RAW Write
    Quote Originally Posted by stile
    I was aware that RAW mode on DVD's was not really intented in the first DVD spec, but everywhere that talks about the subject, most people sound and act like someone, or some CE company is working on a RAW mode DVD player? Am I completely missing something? I thought the whole reason that the DVD spec didn't have RAW was to protect copy protections? Is someone coming out with a DVD drive with RAW mode or software that will support that?? Any one know of anyone toying with the idea?
    It is so choice. If you have the means, I highly recommend picking one up. -Ferris Bueller
