Showing results 31 to 40 of 49
Thread: SR7.Stop
  1. #31
    18.05.2003
    16
    hi.. my question goes to HAANDI... about Pr0t.St0p
    is there a change to see a new unblacklisted version of this nice utility... because tha latest SecurROM from SW EAW seems to stop the functionality of Pr0t.St0p
    I really don't like to request thinks especially from a freeware developer..
    I can play tha game with CureROM but one click solution like Pr0t.St0p is preferable
  2. #32
    Mystique's Avatar
    08.11.2005
    877
    why ? use the AntiSecuROM loader from the 3rd Party App section here on the Page. Works like a charm and its a One Click solution.
    sysProfile (Click me)
  3. #33
    18.05.2003
    16
    I found that Pr0t.St0p working with the new Alcohol 120..(3823)
    without even closing it... just press Hide and Play..SW EAW(example)
    Does this mean that SecureROM blacklisted deamon tools or part of daemon tools?
  4. #34
    Experienced User burnsy_xyz's Avatar
    22.05.2005
    131
    try alcohol withaout protstop and you will see, that it won't work as well. it's the good old scsi blacklist.
    protstop just circumvents that
  5. #35
    05.12.2005
    19
    I tried to reach dtools developers to get a documentation about plugin creating - without any results.....
  6. #36
    @HAANDI
    I don't seem to have a Pr0t.St0p backup to restore... am I screwed? or is there a way to manually restore what was changed...
  7. #37
    LooDos's Avatar
    16.11.2005
    694
    if u restart your system the registry keys are regenerated automatically.
  8. #38
    22.08.2006
    5
    Default SR7.stop screwup
    Hi, sorry if i already have posted this question, but here it goes.
    The SR7.stop (1.2) cant hide or unhide, it just goes into a loop, ive got DTools 4.03 installed with 1 Virtual drive, dont know what happend, but the REG key is also gone, i think it happend after i installed "Safedisk 4 Blocker", could that do the screwup, and how do i revert the screwup
  9. #39
    22.08.2006
    5
    Frage Problem solved, dont know how though!
    Well, dont know how, but it works now, didnt do anything, it just worked, and ahm, any1 trying to help me, please do, might be some1 have the same problem, and that might not be as lucky as me, and i also want to know what the solution to the problem is, as i might not be so lucky another time, thanks on advance.
  10. #40
    22.08.2006
    5
    Rotes Gesicht Another problem now
    Well, its the same app im trying to trick, but now it wont run, i managed to run it 1 time, then i exited the game, restored the Virtual drive, and well, tried to run it again, then it wouldnt run, now, the SR7.stop hide the Vdrive but the app wont respond on the command i give it, its like i dont even run it, hmm... ive got this explorer.exe i have to run before i can run the game, it worked fine before the mishap, or what ever we call something like that (and im going to buy the "app" anyway) but i would like to get it to funktion again... man im babling! Anyway, i got SR7.stop and Daemon 4.03 and that explorer.exe (size 44,5kb in totalcommander reading not explorer!) ive got a Pioneer 110D DVD burner and a LiteOn CD Drive, AMD 3000+ 64 cpu, msi radeon chipset motherboard w, X700pro asus graphic card, 1GB Ram (2x512MB kingston value)! A ton of usb devices (HDDx2 Webcam(microsoft) mouse, keyboard(also micro) bluetooth, Gamepad) thats about it, hope some1 can help
