Showing results 1 to 8 of 8
Thread: How do we make PERFECT copies using Acohol 120% ?
    22.04.2003
    26
    Default How do we make PERFECT copies using Acohol 120% ?
    How do we create PERFECT copies of games using Alcohol 120% ??? Do we need to create images of the game first or something like that or we just click some options and it's done ??? Help Plz, As u see, I'm a noob ! But seriously, If someone could tell me it would be very nice of u !
    ~ Lonfelk
    go here: http://alcoholer.cdr-italia.it
    download alcoholer3.1+clonyyXXL
    use clonyXXL to detect the cd protection, and then open alcoholer, it will select the correct options for you (you need to set if you have a alcohol free drive, a alcohol 50% drive or a alcohol 120% drive, you can find a list of burners on alcohol forum) and will set them in alcohol, the open alcohol and use the alcoholer profile to read and write. That's all
    22.04.2003
    26
    thx ill try, I actually have alcohol 120 %
    alcoholer sets autonatically the options in alcohol 120%, so you don't need to set them manually everytime
  5. #5
    24.10.2003
    2
    Quote Originally Posted by luciano
    Site addy update:
    Code:
    http://www.alcoholer.com/
  6. #6
    12.12.2003
    3
    Making "perfect" 1:1 copies depends as much (or probably more) upon the capabilities of your burner. If you have one of a few reliable brands/models that are able to copy "advanced" protections like the newest safedisk and securom versions, then Alcohol is one of the better choices, but if you don't , it will not matter what you do in the software!
    Remember that there are many many cases where you have to make a compromise and burn a modified image or use some form of software protection emulation (like d-tools or alcohol's emulations) rather than try and try to make a perfect bit:bit copy.
  7. #7
    Here is an updated link for the Alcoholer 3.1a software as the other links no longer work.
    http://www.softpedia.com/public/cat/3/7/3-7-53.shtml
  8. #8
    NARS's Avatar
    07.12.2002
    266
    You can get latest Alcoholer at:
    http://www.aray-software.com
