Page 1 of 5 123 ... LastLast
Showing results 1 to 10 of 42
Thread: When will come out daemon tools 4 pro?
    Default When will come out daemon tools 4 pro?
    as title anybody know what is the release date?
    Daemon-Tools 4 Pro will never come out.
    It's called Daemon-Tools Pro 1.0.
    When it's done, you've to wait a bit.
    Idee
    And here starts the release-date-asking again.
    The Boardzombie's website.
    Mystique's Avatar
    08.11.2005
    877
    I prefer for 1-2 Months, then there will be a stable version of it for every customer. Such thing is hard to code because of vIDE and other components...
    lets wait for what the devs have to say
    sysProfile (Click me)
  5. #5
    LooDos's Avatar
    16.11.2005
    694
    u prefer? maybe u mean "guess", dont u?!
  6. #6
    Default pointing to thread Ide Disabler ?!?
  7. #7
    ok but the DTPro 1 will "fuck" ( ) all starforce version?
  8. #8
    however i can't play this games for the moments until will come out dt 1.0 pro
    trackmania sunrise
    sc chaos theory
    pop T2T
  9. #9
    13.11.2005
    472
    SC Chaos Theory will work.
    You just need DT 4.03 and Starforce Nightmare to Disable your CD/DVD-ROMs (if SFN works for you) ... and a good MDS and SCCT Update 1.04.
  10. #10
    Trackmania Sunrise without the extreme add-on/SCCT will work with SF Nightmare too. Press disable cd. If this doesn't work open device manager search for ide controllers press rightclick on them and look which could be disabled. If the secondary could be disabled then press disable ch2 at SF Nightmare or you can disable it in the device manager but for me it only worked with SFN. The channel which the harddisk uses can't be disabled in device manager so you can look which can be disabled an this should be the one where your drives are connected to. But be careful with disabling.
    For POP T2T you've to unplug your drives, if you don't have an NForce 3/4 board.
