Showing results 31 to 40 of 50
Thread: CureROM Update 1.2.2
  1. #31
    Click on the options button, there you can choose the path of
    DT and if you want to enable it for mounting.
  2. #32
    07.07.2005
    384
    Quote Originally Posted by AnalCobra
    YOU GENIUS!!! That was quite simple, and I was stressing about it. Cheers
  3. #33
    sYk0's Avatar
    27.12.2005
    392
    The new version of CureROM will NOT affect any registry key(s)...
    I've found another workaround for SecuROM 7 and SafeDisk 4 protection and it will be avalible in the next release...
    btw, the new version(1.3 Pro) will only be for Windows NT "32Bit" operating systems, there will be another release (1.2.3) for Windows NT "64Bit" (wich still uses the "OLD" protection).
    Any users that use a 64Bit O/S please be patient...
    Mail:
    curerom @ daemon-tools.cc
  4. #34
    12.11.2005
    2
    Why does CureROM cut off a bunch of stuff on it?
    Running on a widescreen laptop, 1680x1050.
  5. #35
    probably because you're running Windows with a bigger-than-standard font.
  6. #36
    I cant get starwars empire at war to work with this. can anyone help me?
  7. #37
    Same problem here with Star Wars Empire at War.
    Use Curerom 1.2.2 to load LaunchEAW.exe with DT 4.03, and still complaining that emulation software has been detected.
  8. #38
    Use CureROM 1.3.1 then it should work.
  9. #39
    I tried to do the same as Crazydutch(Star wars empire at war) but with Curerom v1.3.0b and DT v4.03 and i get "Original disc could not be found or authenticated." message , I could't find the curerom v1.3.1 anywhere , only 1.3.0b.
  10. #40
    Quote Originally Posted by Swarmdie
    http://www.daemon-tools.cc/dtcc/show...48&postcount=1
    Look at the bottom of the post: links were updated to the latest version.
