Page 5 of 5 FirstFirst ... 345
Showing results 41 to 50 of 50
Thread: CureROM Update 1.2.2
  1. #41
    20.02.2006
    1
    i'm using curerom 1.3.1 and DT 4.03 and it still doesnt work. when i make a profile with the launcheaw.exe it still detects emmulation. i tried using the sweaw.exe but then it gives me an error message abotu not being able to find the original cd.
  2. #42
    20.02.2006
    3
    Using CureROM 1.3.1 and DT 4.03HE i get an error saying that curerom cannot start its anti-blacklist measures. I am the administrator so what could be preventing it from running. I only have DT installed and have used all previous methods said to work by others. Simply something is preventing the anti-blacklist measures and I don't know what.
  3. #43
    sYk0's Avatar
    27.12.2005
    392
    Why does CureROM cut off a bunch of stuff on it?
    check your DPI settings, i'll try fix this for the next release.
    Mail:
    curerom @ daemon-tools.cc
  4. #44
    Böse same problem
    I have the same problem for Star Wars Empire At War
    using DT 4.03HE and CureROM v 1.3.1
    Here is my log:
    [Profile]
    Profile Version: 1.3.1
    [Application]
    File: "F:\PathTo\Star Wars Empire at War\LaunchEAW.exe"
    Path: "F:\PathTo\Star Wars Empire at War\"
    Arguments: N/A.
    Single CPU/Thread: Yes.
    Icon: "F:\PathTo\Star Wars Empire at War\LaunchEAW.exe, 0"
    [Anti-Blacklist]
    CureROM Anti-Blacklist measures: Yes.
    [Virtual CD/DVD]
    Use Virtual CD/DVD: Yes.
    Application: DAEMON Tools.
    Backup Image: "C:\Documents and Settings\XUsername\PathTo\MIR-EAW.mds"
    Device #: 1
    Mount Time: 3 Seconds.
    Unmount Image: No.
    Disable CD/DVD-ROM Autorun: No.
    [Virtual Drive Emulation]
    Use Emulation: Yes.
    SecuROM Emulation: Application Preference.
    SafeDisc Emulation: Application Preference.
    LaserLock Emulation: Application Preference.
    RMPS Emulation: Application Preference.
    [Shortcut(s)]
    Desktop Shortcut: Yes.
    Desktop Shortcut (All Users): No.
    Additional Shortcut(s): No.
    When I click the LaunchEAW icon the error I get is:
    "Original Disc Could Not be Found or authenticated"
    A little help please?
  5. #45
    Böse curerom 1.3.1
    Quote Originally Posted by AnalCobra
    Use CureROM 1.3.1 then it should work.
    i tried it but it dosent work
  6. #46
    13.11.2005
    472
    Don't use the LAUNCHEAW. Use the "sweaw.exe" in one of the sub-directories. (I don't know the exact sub-dir, because I haven't installed it yet)..
    Then it should work.
    @Bobafart: The name of your image is very suspicious...
  7. #47
    20.02.2006
    3
    If you get the same error as I posted before I got it to work by mounting with DTv4.03 and using SecureROM v1.1. Works but still gives me an exception once and a while. Empire at War is patched to v1.02 also.
  8. #48
    Sometimes it works, sometimes it doesn't.
    For example, It works, I shut the game down, click the same icon I made and it will say original disc not found.
    Why is that? Nothing has changed?!
  9. #49
    I can not for the life of me get Crashday to work. I have done all the stuff that people have told me to do. Could someone please give me a detailed description of what to do? Thanks
  10. #50
    sYk0's Avatar
    27.12.2005
    392
    We also need some more information from your side...
    Daemon-Tools version...
    What application(s) are you using to hide your virtual drive(s)?, CureROM or SecuROM Loader(aka AntiSecuROM)...
    Mail:
