Page 3 of 3 FirstFirst 123
Showing results 21 to 23 of 23
Thread: [TIP]Right click menu on image files!
  1. #21
    "(path)" (command) (driver number),(filename+path="%1")
    i dont get that bit.
    is there just something i can install to do this autmatically : /
  2. #22
    i've made 2 registry files that will add/remove shell extensions for mounting all of Daemon-Tools lite supported image files:
    (.b5t, .b6t, .bwt, .ccd, .cdi, .cue, .bin, .iso, .mds, .mdf, .nrg, .pdi, .isz)
    tested on vista with DT lite 4.30.4.0027
    check out the readme.txt for more info.
    download here:
    Send big files the easy way. Files too large for email attachments? No problem!
  3. #23
    ok, tried 2 different .reg scripts now, i dont get any right click menu
    I want a rightclick mount with and a rightclick unmount all.
    it does however mount a image if I double click it.
    im on windows 7 64
    DTlite installed.
    DT pro has these commands, why not lite?
    and i did edit the .reg files to have the correct paths and filenames
