Sorry for the delay. I haven't found the time so far to write a suitable ReadMe with the needed installation instructions. Perhaps next weekend I will have enough time for it.Originally Posted by windtrader
I will hopefully also include a standalone-version that can run without girder. This will not start fully automaticaly as the girder-solution, but you will only have to double-click the script to mount your drives.
Till then you can try the DVD-Decrypter way I've posted before. If you burn your splitted files to DVD-R, take care they reside in the root of the volumes, as the script will not scan subdirs.
corum666
