CureROM Pro 1.3 (Released)
  • #31
    Using the profile setup, whenever I exit the game, it screws up windows so I cant do anything but shut down. Maybe its related to the lite mode bug?
    Odd, it only happens when I have a windows explorer window open to the folder when I exit the game. When I create a shortcut on the desktop and run it there it is able to shut down the cure thingy fine.
    • #32
      Error
      Hello there.
      I'm geting a error.
      "Error starting CureROM Anti-Blacklist measures"
      It says to reboot, but after the reboot the problem still there.
      Can any one help?
      I'm using a athlon 2200 with winxp.
      Thanks!
      • #33
        I'm busy looking into this problem... please be patient...
        Mail:
        curerom @ daemon-tools.cc
        • #34
          Doesn't work with Dawn of War / Winter Assault 1.41, it has newest securom I believe.
          • #35
            The Regiment
            I can't start The Regiment from a backup copy with Daemon Tools 4.03 and CureRom 1.3.1
            • #36
              grrrrmmpfff.
              your post is total nonsense! If you write NO INFOS, NOBODY cant help you!!!
              Here a few things, which are important:
              1: Precision of DPM and which speed?
              2: Does it works with other programms like sr7stop?
              3: Mounted with Daemontools 4.03?
              4: Right CureRom-Settings?
              Try to change your MDS with someone, how really 100% works. you can download this for example at copybase.ch
              I hope you did the right profile at alc-image (securom 4/5 with DPM speed very slow, maximum 4x and high precission)
              Put the daemon.exe in the curerom settings at "third party virtual cd/dvd rom".
              • #37
                The CureROM lite on version 1.3.1 works perfectly with no errors, but when I go to run Star Wars - Empire at War it tells me "Original disc could not be found or authenticated." I am using an image of the DVD with DT4.
                • #38
                  I heard something about CureROM deleting all new files if the computer is not used for 30 mins... is this true??
                  • #39
                    x64
                    This doesn't seem to work properly in win xp x64. Upon exit it crashes everything! Do you have plans to make it work for us x64 geeks?
                    Thanks
                    • #40
                      1.3.1 worked fine with my cd-rom version of EaW, but im just wondering, has any1 updated the game and does it still work then?
                      • #41
                        sYk0, I specifically registered to say "thanks" for your work on CureROM, I'm a new user as of 1.3.1 and very much appreciate the fact that I can continue to play F.E.A.R. (1.03) without having to rummage around for my disc. Great program, many thanks for the time and effort.
                        • #42
                          Thanks...
                          Other users of CureROM please be patient, i'm working on the "Can not start Anti-Blacklist measures" error, it will be fixed soon...!
                          As 4 you x64 geeks hold on... i'll try get a working version for x64 ASAP...
                          If you have any problems with games please check/post it on the daemon-tools forum, do not mail me unless it is related to CureROM...
                          btw, i have a full time job, CureROM is a hobbie of mine so any updates/fixes will be done when i have time...
                          Thanks for all your support and patience,
                          sYk0.
                          Mail:
                          • #43
                            Thanks
                            Same and I use xp pro.
                            The way I got it to work was use the profile mode instead of lite mode. And make sure no windows explorer windows are open when you exit (which means create a shortcut on desktop so you dont start it using windows explorer). Oddly enough this cured the profile mode from crashing the same way as the lite mode for me.
                            • #44
                              Yes it does! I am playing EaW on 1.02, and both CureROM 1.31 and Pr0t.St0p do the trick (obviously I meant both in the sense "one at a time", not at the same time )
                              If the minimum wasn't acceptable it wouldn't be called the minimum.
                              • #45
                                Have you tried Securom loader v1.0 located in the downloads section with eaw? Works for me. Maybe for you too.
