CureROM Pro 1.3 (Released)
  • #46
    Originally Posted by sYk0
    btw, what Anti-Virus are you using?
    I have tested CureROM 1.3.1, with Norton Internet Security, Kaspersky(latest, in trial mode) an ZoneAlarm(wich is what i use...)
    i'll fix the uninstaller to remove the additonal file(s)...
    I use Kaspersky Pro 5.x registered.^^
    • #47
      ^Btw guys ...the Stars Wars problem thread is over at
      http://www.daemon-tools.cc/dtcc/t982...r-save-me.html
      That is definet. no CureRom Problem so its offtopic here
      • #48
        Mail:
        curerom @ daemon-tools.cc
        • #49
          Well if you dont believe me
          Heres mine:
          click for image
          Edit by Underheaven: I replaced the image with a link so the forum layout doesn't get busted anymore.
          • #50
            Well the problem I've been describing is from the cure thing. Its not a star wars problem. Star wars runs just fine, its cure that freezes up my win XP pro (if I have a windows explorer window open after the game exits and it tries to disable the protection, or I tell it to disable the protection).
            • #51
              Well, does anyone else who uses Kaspersky, have this problem?
              Mail:
              • #52
                Here is a direct link:
                • #53
                  I am having problems with curerom v1.3 also. When I try to open settings I have a system lockup and I have to use task manager to exit out. Any ideas?
                  • #54
                    Oh i had that one too but it seems rather erratic and doesnt
                    happen every time.
                    U can close explorer.exe with taskmanager , and then in the
                    taskmanager go to "FILE" -->New Task (i think in english thats
                    how it is) and start explorer.exe again. At least for me that
                    was a workaround.
                    • #55
                      Why u think its only me? Please attach your version of
                      madchook.dll here in the thread and i will get it and
                      scan it. Maybe something is goofy on my rig
                      And you sure that on your kaspersky the dll file is not on
                      the exclusion list already ? The weird thing is you can
                      still scan it then but it wont pop a report even if its the
                      only file you scan
                      BTW I USE THE EXTENDED DATABASE TO SCAN...not the default setting
                      • #56
                        the exclusion list already?
                        Nope it is not...
                        Mail:
                        • #57
                          ok then your not using extended database to scan.
                          • #58
                            sYk0, I'm having persistent problems with Curerom. Every time I try to use antiblacklist measures I get the same response
                            Error starting CureROM Anti-Blacklist measures
                            I have used Dependency walker and found an error, look
                            click for image
                            Delay-load module warning. This module is either missing one or more export functions that are required by its parent module, or is of the wrong CPU type. For a missing export, the Parent Import Function List View will list the actual unresolved functions that are missing. For delay-load dependencies, this is most likely not an error since one reason developers use delay-load modules is when they are unsure if a particular function exists in dependent module. Parents of delay-load modules have techniques for recovering from missing exports in the delay-loaded dependent module.
                            I have no clue what could be the problem. Please help.
                            Edit by Underheaven: I re-linked the image so the forum layout doesn't get busted anymore.
                            • #59
                              @ Sabrehawk, i see you are going to be on my case about this... lol
                              Once again here is another scan result from Kaspersky...
                              Mail:
                              • #60
                                @ Add3T, i'm well aware of the problem, and am fixing it now...
                                This seems to only happen on a few pc's... which is very wierd...
                                I have run into this problem myself on one of my other machines...
                                Mail:
