Page 8 of 10 FirstFirst ... 678910 LastLast
Showing results 71 to 80 of 92
Thread: CureROM & Star Wars: Empire at War...
  1. #71
    Kinlaadare's Avatar
    24.05.2005
    697
    The emulation options of DT are only when there is a physical disc in one of your physical drives.
    When you have an image monted, DT select automaticaly what's needed.
    Carpe diem
  2. #72
    Well that's good to know, thanks.
    Now, anyone have a clue as to how to get this to work with the 1.04 patch?
  3. #73
    FRENCH TRANSLATOR OFFICIAL TRANSLATOR
    07.11.2002
    487
    Set the main exe in Windows 2000 compatibility mode and use Securom_loader V1.2
    Have fun
    Olivier
  4. #74
    Default 1.04
    I didn't have to change my CureRom 2 profile at all to make it work with 1.04. Everything still works good for me.
  5. #75
    07.11.2002
    487
    Yes it works with CureRom 2, I just checked .
    The trick I suggested is for Securom_loader V1.2 .
    Olivier
  6. #76
    Well I must have a bad image because I keep getting this: http://www.securom.com/message.asp?m=emu&c=5000
    The image was mounted by daemon tools but it's not running. Used Securom Loader 1.2 and set the compatibility of Gamedata/sweaw.exe to Win 2000. The CureRom method doesn't work for me either.
  7. #77
    Yeah, sounds like a bad image. Use crAlcohol 120% to eate your image and enable the DPM option in the read settings with high precision and a slow speed (1x-4x).
  8. #78
    Quote Originally Posted by OlivierFromFrance
    Have fun
    Olivier
    Doesn't work...I get a "Conflict with Emulation Software detected" error
  9. #79
    05.06.2006
    2
    Default This might help with DT4+curerom+EAW to get running
    Hi all,
    I have Dtools 4 and curerom 2.1 it seemed to work
    but after first working it refused saying on ver1.0
    please insert original desk. patchign to 1.04 the msg changed
    to please insert orginal disk backups arent allowed (1000)
    or something like that by memory.
    THe fix is quite simple.. it creates some files in your temp folder and gamedata folder that tells its a image loading.
    just nee to delete them and it will fire up each time no
    problems
    here is a batch file I wrote.
    I have game on G: drive and curerom in c drive
    first you need to make a profile with curerom 2.1
    to mount the image and start that game
    then you need a batch file to clean up each time
    and call curerom profile to start game
    like so, else it might work 1 in 10 times like some reported
    or not at all. of course a image MDF might help since it has
    extra info over other isos.
    del /f /q %temp%\*.*
    del /f /q "G:\Star Wars Empire at War\GameData\*.rec"
    cd "C:\Program Files\CureROM\"
    c:
    "C:\Program Files\CureROM\CureROM.exe" -launch "C:\Program Files\CureROM\Profiles\LaunchEAW.crp"
    enjoy
    P.
  10. #80
    05.06.2006
    2
    Quote Originally Posted by psspss
    The fix is quite simple.. it creates some files in your temp folder and gamedata folder that tells its a image loading.
    just need to delete them and it will fire up each time no
    problems
    c:
    I tried that, didn't work for me. I'm running version 1.04 of the game. Yes, i corrected the paths, they are referring to the folders I'm using. After the second command (del /f /q "G:\Star Wars Empire at War\GameData\*.rec"), I get an error message saying that it couldn't find any files, and then it goes on and loads the CureROM profile. Of course it will then only start about 1 out of 10 times. Any ideas?
