Page 9 of 10 FirstFirst ... 78910 LastLast
Showing results 81 to 90 of 92
Thread: CureROM & Star Wars: Empire at War...
  1. #81
    use sd4hide not curerom and it will work fine
  2. #82
    27.09.2005
    822
    weird, i thought sd4 hide was purely for safedisc games....
  3. #83
    What I did ater gotten both the error and the missing security message(I have Win XP Pro SP2):
    1.Downloaded and installed CureRom Pro 2.0.3
    2.redone my profile(although I can bet was useless)
    3.Redone the shortcut pointing to sweaw.exe
    4.settings on 1st page anti-blacklist checked only
    5.on second use daemon tools and Suspend Cd/DVD . rest default
    ________
    Kept image NOT loaded into Daemon Tools.. clicked on shortcut and fired up
    Also I patched the game to 1.4
    ________
    The only downside I see is that it checks way too much(5-15 sec) before starting the game(then again last time I played it was 1.2 and several months back so I cannot remember if that`s what happened the first time I instaled it)
    Hope this helps
  4. #84
    sYk0's Avatar
    27.12.2005
    392
    The cd-check with 1.4 update is much more aggresive than that of the previous versions, thats why the SecuROM check takes longer.
    Mail:
    curerom @ daemon-tools.cc
  5. #85
    I can't get this damn thing to work either. I got the CureRom profile done, daemon tools settings right (Safedisc, Securom, RMPS, Secure Mode) but it keeps telling me unable to mount image, file not accesable.
    Its trying to mount EAW_1.mds
    help? >.O
    -- Locus
  6. #86
    Make sure the mds and mdf file of your image have the same name. Try disabling your antivirus before mounting.
  7. #87
    mdf? What the hell is a .mdf?
    I have EAW_1.mds, and Star_Wars_EAW_CD1.cue
    -- Locus
  8. #88
    @Locus:
    How did you created your image - which application did you used
    and which settings?
  9. #89
    That's a rather uncommon combination, what program did you use to create the EAW image?
  10. #90
    24.06.2006
    16
    I used KRKSecurom_Loader_1_2 and EaW patched with newest update and it works correctly
