When i mount my Flatout 2 CD1 (got 5 CD's) with DAEMON Tools 4.0.6 ( all emulations on ) Windows doesn't recognize the cd... In My Computer it shows CD Drive (G
and when i click on it I get this message: "Windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compatible with Windows."
What should I do? Or try doing?
Thanks in advance,
Xinck
and when i click on it I get this message: "Windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compatible with Windows." What should I do? Or try doing?
Thanks in advance,
Xinck
, so you'll never get an answer...
