Problem with Railroads
    Used 1x speed for DPM and mounted image but got the error to insert the original disc.
    Disabling the physical Optical drive works but there has got to be a better way.
      Did you try to install from your image drive? I had the same problem initally, but a re-make of the image, and installing from the image helped. btw, the new 1.1 patch doesn't work with v-drives right now.
      It is so choice. If you have the means, I highly recommend picking one up. -Ferris Bueller
        Also Probs with V1.1
        Hello with the first version of RR i got no Probs.
        Deamon 4.06, sec rom loader 7.26, only 1 drive behind HDs.
        other Drive deaktivate. Prog runs fine.
        Now i got Patch 1.1 and install it, but not get it to run.
        Error Message"SM Railroads cause a Problem and will be stop."
        Anyone a Idea ?
        I have an Image with Blindwrite.
          just a couple hints:
          - BW's "EZ Play manager" must be disabled
          - no need to remove opt. drive(s)
          - try using the new version of yasu (1.03)
          should work fine
            YASU 1.03 with daemon-tools 4.06 works fine for me also after patch 1.0.1.0... just mounted, all emu options on... then run yasu 1.03 and start the game...
              They released a new patch today,patch 1.10. It doesn't seem to work with dt 4.08 and yasu 1.4. Anyone got a fix yet?
                Try YASU 1.05 pingkiller.
