yup they're a release group who modified the asr loader and claimed it as their own....
Star Wars Empire at War Forces of Corruption SECUROM
What do you mean by "IS NOT WORKING"? Does it give you an error message? Does it just hang and not run? Does it fly your monitor around you in a "Exorcist" kind of way? In what way doesn't it work?Originally Posted by hideI have a original image from my dvd ...make with alcohol 120% and IS NOT WORKING...why???
So simple he give me error "insert original disc"Originally Posted by Jito463What do you mean by "IS NOT WORKING"? Does it give you an error message? Does it just hang and not run? Does it fly your monitor around you in a "Exorcist" kind of way? In what way doesn't it work?
Ok I find the right way.... I will explain how to launch the game for everybody here...
For fu** the securom you need to make a really good copy of disc...what u need is:
1 good dvd (or cd) drive
2 Alcohol 120%
3 Daemon tools 4.06
4 The original disc of the game (i have tested just dvd version)
First make a new image with DPM extraction HIGH PRECISION and the LOWEST speed for DPM extraction (for me 1x)
Then mount image with the latest daemon tools without any emulation active and without cuerom or yasu.
Then launch the game, if the game dosen't start that's mean ur disc image is not good enough.
Cause for not good image:
- too speedy dpm extraction
- wrong settings in alcohol
- dvd/cd drive is not dpm extraction capable
I hope it's clear for everybody... however for pirated version I think now don't work anymore if the iso is not really good...but is not a problem of us ...just original game guys!
Hi!
Its my proplem too. My image from "forces of corruption" dont work. i used the last alcohol version, dpm extraction high and speed 1x .... ( and shure, Daemon 4.06)
My images from "Fear- Extraction Point" and "Dark Messiah" works fine.
I used the Toshiba 1602 DVD-reader. Its four/five years old, so i think i must buy a new reader.... Can anybody tell me which DVD-Reader (IDE) its very fine to Read dpm from DVD?
Thanks
