If you have the same problem with the original then try this (taken from ubi forums):
- Install the December distro of DirectX (i.e. the latest one) just in case
- what gfx card do you have? Updated drivers?
- Create a shortcut to your desktop to your SplinterCell.exe with a path like this:
"<GAMEDIR>\Tom Clancy's Splinter Cell Double Agent\SCDA-Offline\System\SplinterCell4.exe" -II (those are two captial i's, which should activate the log function)
Hope that helps
Hope that helps
