DAEMON Tools Extensions (DTE)
This is a sticky topic.
  • #61
    Thanks for the info - will take a look into PowerISO.
    EDIT: It seems PowerISO is using same/similar driver as UltraISO and therefore that bug. Will be fixed in next version.
    • #62
      Ok, i tried to uninstall PowerIso, didnt work!
      Damn
      • #63
        norsefire, have you other virtual drive software installed? Have you disabled virtual drive of PowerISO?
        Anyway next version will fix it.
        • #64
          I finally got DTE working perfectly, although i still cannot get Wanted to work! I have a LEGAL Backup of the game since i dont want to bother with switching DVDs when i change games, i get securom error 7000 even when cloaked with IDE drive =(
          • #65
            Have you tried the way from SecuROM website?
            Also please scan game exe with ProtectionID for exact SecuROM version.
            But since rafu997 get insert original message, it seems DTE is not blacklisted yet.
            Anyway i will check that game and SecuROM, just will take a while until the disc arrives.
            • #66
              The game runs when i use the disc, but i hate using discs since i have a collection of approx 300 pc games, and maybe 30 games i play regularly.
              Update: Its SecuROM Detected - Version 07.39.0005
              • #67
                @varxx
                which version of daemon tools pro is windows 7 compatible?
                • #68
                  None so far, you have to wait for SPTD update.
                  • #69
                    slowly getting there,
                    DTE was not working due to the fact i had a MagicISO drive still active but now its saying "No cloaking required"
                    anyideas?
                    • #70
                      DTE tool is useless
                      It doesn't do anything.
                      I double click the DTE.exe and all I get is this:
                      It's a non interactive screen. There is no way to right or left click on it to select or set anything with this.
                      • #71
                        It is not useless, just disable other virtual drives, e. g. from UltraISO/PowerISO/MagicISO and then it is working.
                        You should also search before posting.
                        • #72
                          anyideas?
                          Maybe it is already cloaked and therefore DTE states that.
                          • #73
                            new ver doesnt work here, screen appears, does nothing, then disappears, i do have ultraiso installed...
                            i suspect the problem with ultraiso/poweriso virtual drives is that they don't return anything on an ioctl to get the vendor, revision, product etc... unless the size of the buffer is EXACTLY what is needed (0x1c if i remember right).. anything more, anything less, you get nothing...
                            also new version crashes in win2k sp4
                            Code:
                            004060B6   66:8B00          [b]MOV AX,WORD PTR DS:[EAX][/b]
                            004060B9   68 840921A3      PUSH A3210984
                            004060BE  ^E9 EFB8FFFF      JMP DTE.004019B2
                            EAX 04A67F65
                            ECX 000000B4
                            EDX 00401A37 DTE.00401A37
                            EBX FFB0BE91
                            ESP 0012FE28
                            EBP 0012FED4
                            ESI 0048D399 DTE.0048D399
                            EDI 0012FE30
                            EIP 004060B6 DTE.004060B6
                            access violation....
                            • #74
                              Hi all,
                              Does anyone know how to uncloak a virtual drive cloaked with DTE?
                              Thanks
                              • #75
                                hy guys i use dte.exe ver 2.2.10 but doesn't work. I have created one virtual ide device, then i click on dte, but don't show me the ide device why ?
