ok, so here's my deal:
so far i've burned the image onto a disk, didnt work
mounted the image with both daemon and alcohol, didnt work
when i hid my virtual drives with virtual cd hide, the game gave me the security error:
"A required security module can not be activated. This program can not be executed."
so when that alone didnt work, i tried the .bat code for the scsi number of the virtual drive and for all the virtual drives. first of all, neither of the codes worked. i dont know why exactly, but after i tried to run them, it gave me a list of things that subinacl could do, but thats it. i replaced the paths in the code with the ones that are right for my comp, but it still didnt do anything.
so then i went and manually denied access through registry. now that was all good and dandy until i tried to rename the virtual drive with daemon... then things went bad... a few seconds after i changed the devices name, i got the infamous blue screen. from then on, i couldnt open daemon without getting a blue screen, so i had to uninstall daemon and undeny access for my drives.
apparently i did something wrong, but i dont know where. i gues right now i'm wondering how do you change the name of a virtual drive, and has anyone actually gotten the game to work using these methods? also, does anyone know what i did wrong with my .bat code or why it didnt work?
thanks in advance, all!
