works with SFnightmare v1.12
hey dude!
if i:
FEAR v1.02 works fine.
if u do it this way it should work, otherwise your DPM may be crap. i have the DVD version so my DPM wont work with ur vs...
CYa LooDos
hey dude!
if i:
- disable node
- disable CD
- disable node
- secondary master off (in my case)
CYa LooDos
