2 of the most important things:
1. You have a good .MDS file with RIGHT DPM information!
If you have OWN the Original Boxed game, it is NOT illegal if
you use a Backup-copy,so on some sites was .MDS file, e.g.
Gamecopyworld (as the name tell it all) or copybase.ch.
I have the EURO Multilanguage DVD, I simple make Image with
Alcohol latest and CHANGE the .MDS file for the GOOD one.
(I put back my Original DVD for a while).
2. If you have a GOOD image, simple Mount in DT4 (I SET al-
ways EMULATION -> ALL OPTIONS ON).
Use Starforce Nightmare v1.12 and set DISABLE CD/NODE
+the channel/port you have CD/DVD drive.
Ofcourse use your included Starforce CDkey or didn't works.
I Updated to v1.04 next v1.05 and this method WORKS.
BUT: I used WinXP SP2/ONLY 1 VirtualDrive (NO Alcohol or
other VD configured!). Also If you have installed OTHER
Starforce game try SFDRVUP. IF DO NOT have another SF
game installed BUT REMOVED/UNINSTALLED any, use the
SFCLEAN or/and SFDREM (StarforceClean and Starforce
Driver Remove) programs (DOWNLOAD from official Starforce
site e.g. http://www.star-force.com/support/ etc.)
